Allroad Timing Belt Job
Old Sep 16, 2010 | 10:32 PM
Zachariah's Avatar
Default Allroad Timing Belt Job
Does the front end need to be removed to do this job? What is the hours involved?
Old Sep 17, 2010 | 03:43 AM
roadrune's Avatar
In general, it's about a years work, if you tell us which year and engine you have, it might be less
Old Sep 17, 2010 | 07:50 AM
bob martin's Avatar
Doesn't matter the year or engine, the answer is yes, the front end has to go into service position to replace a timing belt.
And it only takes six months, not a year.
Good luck,
Bob
Old Nov 13, 2010 | 02:53 PM
Jeka's Avatar
Yes, you have to move the front end to the service position
Jeka's Avatar
You need to move the front end to service position. All job takes about 5-8 hours (depends on your experience) and you need special tools. You can get all parts from blauparts.com The same place you can rent the tools.
Old Nov 13, 2010 | 08:01 PM
bigdadi's Avatar
http://www.audiworld.com/tech/eng.html
3.0 V6 timing belt service
Old Nov 14, 2010 | 01:55 PM
host23age's Avatar
i have bnib blauparts timing belt kit for 3.0 V6 if you need it. i'll sell it cheap
Old Nov 15, 2010 | 04:55 PM
Theiceman's Avatar
i found " service position" a little hard on my back .. so i disconected the rad on drivers side and swung whole front end out of the way .. boy was it ever worth it ...
Old Nov 16, 2010 | 11:47 AM
hxgaser's Avatar
He had 2.7T... not 3.0. And yes the front end is removed or put on a service position.
Old Nov 17, 2010 | 03:23 PM
Khardysius's Avatar
If I remember correctly, the timing chain on a 4.2 Allroad is on the rear of the engine. Didn't see whether or not the OP posted his engine type. I would imagine the 2.7t could be easier to access hence taking less time/difficulty.
My AWN took 3 week-nights of about 3 hours each night to complete the job for a mechanically inclined beginner. Yes to service mode (although my passenger side kept trying to slip back in place so I had to jam something back there to hold it in service mode). Blauparts kit and tool rental weren't bad. The cam seal remover tool didn't work worth a lick, so I used a seal remover tool from the parts store; worked fine. Used it for the crank seal as well.
antons987
Jun 25, 2015 12:18 AM
Kevin Artz
May 14, 2012 06:21 PM
Kevin Artz
May 13, 2012 03:39 PM
Juno
Dec 13, 2009 01:04 AM
mav82
Nov 20, 2007 10:54 AM
