Antenna replacement Audi C5 Avant 2003
Old Jun 30, 2014 | 04:30 PM
rumpan's Avatar
Default Antenna replacement Audi C5 Avant 2003
Hey!
The rubber on my original roof antenna is damaged and the antenna with base needs to be replaced.I've got the diversity system which I guess makes things a little bit more complicated. I got one thin coax cable from the roof antenna which connects to the diversity box. I guess that antenna cable is powered with 12v. Can I just cut and use the original coax cable with one of these antennas? :
http://www.ebay.com/itm/VW-Auto-Sport-AM-FM-Haifisch-Shark-Fin-Radio-Dach-Antenne-Haiantenne-Dachantenne-/140975786739?pt=Accessoires_Weitere_Kleidung&var=&hash=item20d2cfcaf3
http://www.ebay.com/itm/Shark-Antenne-Audi-A3-A4-A6-80-90-100-TT-HaiFlosse-Haiantenne-Fin-Dachantenne-/250915926058?pt=DE_Autoteile&hash=item3a6bc1302a
In that case, which one should I choose? Is it better to chose the amplified one and just connect it to a 12v ignition, or will it be damaged because of the already 12v's running in the coax cable to it?
Thanks!
suziebee
Apr 17, 2013 12:39 PM
mercap
Jul 6, 2010 06:38 PM
anymtn
Jul 7, 2007 12:18 AM
wongo
Apr 23, 2007 07:14 PM
njackson
May 10, 2006 04:33 PM
