AudiForums.com
1  2
Page 1 of 2
Go to
-   Audi A6 (https://www.audiforums.com/forum/audi-a6-9/)
-   -   Anyone use laser thermomoter on tranny pan? (https://www.audiforums.com/forum/audi-a6-9/anyone-use-laser-thermomoter-tranny-pan-143212/)
hottubbrad Dec 19, 2009 10:43 AM
I have one of those laser themometer guns at work and was wondering if anyone has used it to measure the bottom of the tranny pan when they are refilling the oil. I would think you could restart the car and let the fluid get up to temperature and test it this way.
Shouldn't the metal pan be very close to the oil temperature?
Saves me buying another Audi tool.....
bob martin Dec 20, 2009 07:47 AM
Should work.
Bob
auditech79 Dec 20, 2009 11:39 AM
Well the temperature sensor for the trans oil is located on the cooler, so you may be reading a couple degrees higher from the pan, so i would give it 1-2 degrees difference in the + side when you change the fluid, you CAN'T LET IT PASS 34 degrees celcuis when filling it. If you don't get it all in by that temperature it will be underfilled and start spilling out before you need it too.
jonus079 Dec 20, 2009 06:15 PM
my question is: AUDI, WHY DIDN'T YOU JUST PUT A FREAKIN DIPSTICK ON YOU AUTO TRANSMISSIONS LIKE EVERY OTHER CAR COMPANY DOES!?
bob martin Dec 21, 2009 08:24 AM
How many cars have you looked at lately? You might be surprised how many are in the no-dipstick camp.
Bob
madridlover Dec 21, 2009 09:41 AM
BMW are in the no-dipstick camp too.
What I do is drive around for a bit to make sure the tranny is hot as hell. then raise the car and put it on 4 jack stands. Wait about 30 minutes and touch the pan with your hand. If it's too hot to the touch then wait some more; when you can touch the pan with your hand without yanking back from in pain from intense heat but you can feel that the pan is indeed hot, then commence to drain the pan.
auditech79 Dec 21, 2009 11:05 AM
Many american automakers don't have dipsticks as well, FORD also doesn't use them since about 05 or so.
You should see the new audis! They don't even have an ENGINE OIL DIPSTICK! Its all read by the MMI electronically.
NH_USA Dec 22, 2009 03:28 PM
After seeing the dipstick oil commercial I can understand why Audi eliminated it!!
No self-respecting German would want to be hit in the butt by a Scotsman with a dipstick!
As for using your hand to check the temp -- I belive there are better things you can do with your hand.
PS - It isn't hard to use VagCom ----
PSS - I think it is an IR thermometer - not laser.
auditech79 Dec 22, 2009 04:38 PM
LOL, i love that stupid castrol commerical.
madridlover Dec 23, 2009 09:27 AM
Quote:
Originally Posted by NH_USA (Post 1159069)
As for using your hand to check the temp -- I belive there are better things you can do with your hand..
I know right..it gets plenty of usage. :)
PS - It isn't hard to use VagCom ----.
Don't have one.
Don't have that either.
1  2
Page 1 of 2
Go to
