aud c4 a6 knocking noise
Hello all..well i got another problem with my lovely 1994 a6 audi.
just a few momemnts ago i came of the highway..and just before i stoped at the lights i heard a knocking noise, i figured it was a blown tire so no worries. so i went to stop on the nearst suitable place and everyting was fine. then when i drove of, the knocking noise got worse! it seemd to get louder everytime i swithed up or down a gear..it sounds like metal to metal knocking. i jacked up the car did a quick inspection of everythin and nothing is loose or damaged. anyone got any ideas? any and all help will be appriciated. audi a6, 1994, 2.8 quattro cheers, zw |
You haven't said where you think knocking is coming from, it needs to be put on a rack if it's a chassis noise and gone thru...might just be a lose exhaust issue but could be many things under there..if your not running forged OEM wheels you could have a broken wheel etc etc Don't drive it until you know whats going on. Keep us posted.
Well i jacked up the car, its not the exhaust or the wheels..theres nothing loose there, no damage whatsoever...
the noise is only present when im in gear (manual transmission). i thnik it could be the diff or the driveshaft..its definitly coming from the back of the car. and im sure its not the transmission..im stumped :mad: |
sCould you feel unusual movement on the driveshaft couplings? IMO,it really needs to be up on a rack and checked to pin down the exact location of the noise., it has to be driveshaft or rearend if it's coming from the rear you'd think..could it be a wheel bearing but then it would always make noise regardless of in-gear or out.
Naah it aint the bearing..it just makes noise when its in gear and he moment i switch between two gears..well since its the tiem of the hollidays ill have it up on a ramp next week..meanwhile ill prey theres no snow since i cant play on it :)
ill keep you posted. |
You say you have a A6 from 1994? In 1994 there was the Audi 100, instead of the A6.
You may have a bad CV joint or worn suspension. Do you have FWD or Quattro? |
Am..there were both 100 and a6, in 1994 they started with the a6 and dropped the 100.
and its quattro yes (read the first post). whats a CV joint? and its not the suspension becouse the knocking is only present when in gear. |
hcw meant no harm by his question: the C4 A6s are known as being built between 1995-1997. Even the repair manuals exist accordingly. However, the crossing "manufacturing" lines are a bit "blurry" for 1994...
Anyway, it is good you have a 1994 A6, as it looks much better than a 1994 A100... If you don't know what a CV joint or axle is or what does, then it is advisable you should take the car to a shop. |
Well i didnt mean to "attack" him, sorry if it seemd so, im jsut generaly frustrated by my audi atm..
and i probably know what a cv thingie is, just not in your language/sleng. i did work on a number of audi c4's in general, audi 100, audi s4/s6, etc. i narrowed down the problem abit, the sound is coming either from the back diff or from the driveshafts at the back or from the center diff, but since i dnt have a ramp i cant figure it out. im of to the workshop on monday i hope. |
One of the driveshaft's sprocket or smt like that, got loose and then broke. now i need a hole new driveshaft (the one from the diff to the wheel).
abit of an expansive job, but i managed to find a used one for abit less money. tnx ya'll for the help :) |
