AUDI 19" RIMS
Old Feb 27, 2008 | 12:59 AM
xp158814997's Avatar
Default AUDI 19" RIMS
I just got a 19" (245 40Z R19) rims for my 2002 AUDI A6 (V6 3.0) . feels not safe. Is that gona fit on my audi?
Old Feb 27, 2008 | 05:46 PM
ppgoal's Avatar
Default RE: AUDI 19" RIMS
I'd never go to 19" because of the low sidewall. Here's what I run on my 2003 2.7T....
235/45 R17 Pirelli P6 All-season; OEMs
235/40 ZR18 ContiExtremeContact; Velocity RS4 Replica Rims
A 245 is a wider/taller tire than a 235. Note that as you go from 17" to 18" the profile aspect goes from 45 to 40. Under that logic, going to a 19" means a 35 profile (if such a thing exists). Otherwise the tire diameter is greater than stock which could rub the fender or chassis, and the speedo will be off. Having said that, there are guys on this forum who have run 19" rims and they should chime in with what size tires they ran.
Old Feb 27, 2008 | 05:54 PM
formulagigi's Avatar
a 19 is not an issue but the tire size you picked is way off.
normal size would be 235/35/19 I used to run a 245/35/19 to get a little extra tirewall... and overall diameter was within acceptable range. BUt 245 40 is way off, check the tire calculator on discounttire.com
Old Feb 28, 2008 | 03:02 AM
Vegas34's Avatar
If you go with 19's and the speedometer is off a bit, can't the computer be adjusted to read correct speeds?
Old Feb 28, 2008 | 01:51 PM
I am sure he can but this is just real big for a 19 tire on an A6. Not sure it'd fit in the first place!
Old Feb 29, 2008 | 11:29 PM
loydma3's Avatar
hey guys- how much do you reccomend lowering the A6 after your put 19's on it-
ocadena
Oct 26, 2011 02:23 PM
rityim
Oct 26, 2010 03:56 AM
PodgoricaB6
Mar 13, 2009 05:24 PM
1.8TurboAudi
Jun 5, 2007 11:29 PM
