Audi A6 C5 Avant headlamp washer question
Old Nov 22, 2013 | 06:00 AM
infestdead's Avatar
Default Audi A6 C5 Avant headlamp washer question
Hello guys,
I have a Audi A6 C5 Avant 2.8 quattro bought second hand and the headlamp washers do not work. I've looked at the front - and the washers are OK themselves - but the hose that should lead liquid to them goes nowhere - if I put compressed air in that hose - that raises the washers.
The question is - is the washer reservoir the same on models with headlamp washers and without? Do I need another reservoir, does this work on a separate pump, and I need just another pump, which goes where?
I looked through part catalogs and I can't find anything.
Thanks in advance,
Ivo
Old Nov 22, 2013 | 08:08 AM
Huskerbob's Avatar
Originally Posted by infestdead
Hello guys,
Thanks in advance,
Ivo
If you can take a look a the reservoir you should see a plug facing the front of the car and a spot for the washer pump for the headlights. There should also be a plug sort of hanging there for the pump. You will need a pump and some tubing to complete the circuit. Try taking out the driver's side wheel well liner and you should be able to see the whole reservoir. Reservoirs are not too expensive, $35, if you need a new one. Not sure how much a pump is but see if you can find one with the hose and the quick connects. Try audihausaz.com or google it. Ebay always has some as well.
Old Nov 22, 2013 | 09:03 AM
infestdead's Avatar
Thanks for the reply, I'll have a closer look. Not that I need the headlight washers, but having them available and them not working is frustrating.
Old Nov 22, 2013 | 10:15 AM
Huskerbob's Avatar
They are nice in winter conditions but they use a boatload of fluid with each wash. They are designed to only work when the headlights are on and you use the windshield washers.
towerpower
Jul 27, 2010 09:07 PM
crossbronx
Mar 27, 2009 06:24 AM
Snapperanton
Jan 6, 2009 06:32 AM
AudiOso
Apr 22, 2007 03:20 AM
Digicool1
Aug 15, 2006 08:36 PM
