Avant rear wiper assembly
After taking off the back trim on the lift gate to solve my leaking washer fluid problem. I discovered that the fluid was not leaking from a hose, but instead coming from inside the motor assembly. I took it apart to find that the copper tube that on one end sprays the fluid out onto the window and the other end connects to the washer fluid supply hose was broken in the middle. This causes the fluid to leak inside the housing and out two little holes next to where the fluid supply hose connects to. I can't see any conceivable way of fixing this so my question is; where do I get a new wiper motor assembly? I can find the ones for the front of the car but not the back.
Any suggestions would be greatly appreciated.
Jeff
Jeff
Audi do a repair kit called 'Rep Satz', part number 8L0 998 711.
Comes with all the bits to replace the broken tube and the geared crank/wiper-drive-shaft (although the geared linkage in my kit was too stiff and took me a couple of hours to loosen it up!!!), also includes a new gasket, nozzle jetand o rings and greases and instructions!!!
