average oil temp while driving
Old Apr 22, 2008 | 03:50 PM
domvr6's Avatar
Default average oil temp while driving
Ive noticed my car which is a 2000 A6 2.7t will go up to about 250 degrees(middle) and then some times itll fluctuate and go up to 300 (close to red but never hits it) then back down. I was curious if everyone elses 2.7t engine stayed at one oil temp or if its normal for it to change like that.
thanks
Old Apr 22, 2008 | 04:25 PM
shatcher's Avatar
Default RE: average oil temp while driving
I dont know if it will help, but I drive a a6 and my oil temp gets to around 100 C. Never gotten any higher than that, its the quarter on my dial.
Old Apr 22, 2008 | 06:19 PM
event's Avatar
Member
That sounds suspect, I've driven my A6 at high speeds for 4 hours straight before and didn't get passed the half way mark, might want to look into that depending on other responses.
Old Apr 22, 2008 | 07:56 PM
nothing77's Avatar
Those temps seem real high, I mean above the temp that oil breaks down. My temps are about the same as shatcher's. Only in real hard driving do my temps rise above 1/4 on the gauge, as soon as I let up the temp begins to drop back to what is normal for my car.
Old Apr 22, 2008 | 08:32 PM
joetm's Avatar
just shy of the middle like 250ish
Old Apr 22, 2008 | 11:05 PM
GDET09's Avatar
same here 200-250 usually
Old Apr 22, 2008 | 11:40 PM
formulagigi's Avatar
200-225
Old Apr 23, 2008 | 01:39 PM
hxgaser's Avatar
Usually around 200 to 225. Goes up to near 250 when I am climbing California Sierras doing 80+ mph. 300 does not sound right.
Old Apr 23, 2008 | 05:06 PM
domvr6's Avatar
today its been sitting right under 250. Somedays its fine and then others itll climb and drop. Where is the oil temp sensor located? Is it possible its going bad? Has anyone heard of it going bad?
Old Apr 23, 2008 | 09:19 PM
gottwinns's Avatar
250 seems about right but 300 is not normal. Mine never budges the 250 mark even when i am stomping on it
aeeroN
May 11, 2011 08:33 AM
Jackmup
Apr 7, 2009 09:51 AM
transducer
Jan 4, 2009 11:53 PM
transducer
Dec 28, 2008 06:49 PM
TopSpeedCustoms
Sep 12, 2007 03:29 PM
