blown right side turbo
RE: blown right side turbo
I'd suggest you search the C5 A6 and the B5 S4 forums on www.audiworld.com. Pretty high-level brain trust over there to help you with the problem.
Good luck.
Good luck.
blown is a relative term. an internal oil seal ruptured spitting oil into the compression side of the turbo. Basically I'm spitting oil into my engine. I only noticed it when I saw a smidge of smoke under heavy acceleration, I brought it to a shop and they took off the charge pipes connecting to the throttle body and saw that the right side pipe had oil and sludge in it. the turbo was also leaking a small amount of oil. The car actually drives fine right now just not performing up to standards and burning a little oil.
