brakes..Is there a
Audi's are not the only vehicle to requirethe pistons be turned when pushed in, so most shops have the tool. A smart fella can do it with a pair of channel locks and a regular piston retractor if he is careful.
But you can get a cheep one on Ebay for around $20 that will work ..
http://cgi.ebay.com/ebaymotors/NEW-D...spagenameZWDVW
Brake noise?
Depends upon what noise they make. If they are worn out it could be metal against metal grinding. (BAD) If it is squeal you might need a bit of the spry on stuff that goes between the pad and piston to quiet them down.
Iseldom have trouble with brake noise whileusing standard pads and rotors - the only thing was squeal and that was an EZ fix.
i put the spray and the cream on still doesnt do a thing ... pads replaced by dealer like maybe 5 months ago and they are still fresh ! ... i always have had noisey brakes on audis ... maybe the way i drive? i have no clue but i put slotted and drilled on my s4 and they never made noise after they warmed up! ive been hearing about hawk blue pads so maybe ill try them before i splurge on some brembros haha
