break job questions
Old Jul 15, 2009 | 11:14 PM
james0013's Avatar
Default break job questions
OK so I am planning to change the front breaks on my 2000 A6 2.7T. The shopping list is as follows
Stock Audi/VW rotors ( decided that slotted, drilled or slotted and drilled rotors were not worth it)
Hawk High Performance Street pads
Super blue break fluid
My problem is that I dont know which hawk HPS pads to buy, I want to make sure I maintain the function of the break ware sensors, secondly were there different types of connector used on our cars? square, round, round square or square round?
Also I am nearly certain my car has 16.7mm offsets but can someone confirm
also how much break fluid will I need?
My main aim here is a setup that will reduce the chance of the rotors warping
thank you in advance
james
Old Jul 16, 2009 | 01:31 AM
Cmoney's Avatar
I have the same make and model. You have to buy the 8 pad set that has the connectors built in if you want to keep that function.
I wouldn't use any other thing other than an Audi/VW approved fluid and I would have the system flushed. YOu are suppose to do that every 2 years or so. It's not hard to change the pads and rotors on the 2.7.
Old Jul 16, 2009 | 11:22 AM
hxgaser's Avatar
The only sure way to tell is to take the front wheel off and take a look. You can tell whether you have 2 pad ATE calipers or 4 pad calipers. Also at the time, you can measure the offset.
Other option is to go ask a dealer with your VIN to tell you exactly what you have.
Old Jul 16, 2009 | 09:36 PM
james0013's Avatar
I called the dealer with the VIN and he said that I had 4 pad calipers, he did not know what offset I have so I am going to have to take the wheel off for that. I am assuming that they will be 16MM offsets.
Old Jul 17, 2009 | 09:03 AM
Jackmup's Avatar
If you are changing the fluid with the same color (clear or gold) get 3 liters. If you change colors and use blue dyed fluid from Blauparts.com you can get away with 2 or less because you will be able to see the new fluid as it bleeds out. I used blue the last time and it worked out better.
Remember to prep your fender and work clean because the fluid will eat your paint and tires etc.
pyjami
May 15, 2014 06:43 PM
NuYorka103185
Oct 20, 2009 10:01 PM
Clickyurdead
Jan 30, 2009 12:42 AM
ducracer21
Jun 20, 2007 03:30 PM
clconversion
Jun 29, 2006 06:36 PM
