brembo big brake kit '00 2.7t
on awe-tuning.com site, brembo brakes big brake kit 355mm for my 2000 2.7t cost about $3,195 just for the kit, - install. Anyone know where I can get this kit for cheaper, preferably online.
RE: brembo big brake kit '00 2.7t
www.ecstuning.com
great place to order anything u need
edit: stage 3 for our cars is like 1800 bucks..
well those are stock, off a twin turbo porsche. so they should do the trick just fine. you could go brembos, but would be paying mostly for name. i dont think u would find a noticeable difference between the 2.
when its time for my brake upgrade, im going stage 3 or 4. if 4's fit under my stock bbs' ill go 4, if not then 3 is fine.
4's need an 18 and possible spacer. I'm really liking the yellow calipers of the porsche though. My setup would be ebony pearl, privat 17's and yellow calipers if i stick with that. Total for it all will be about 4 grand, waorth it. Hey rs, will this rim tire combo work? PRIVAT PROFIL 9.5X18 5X114.3 ET40 rim work with 245/45/18 W sized tire?
The bolt pattern for an A6 is 5 x 112 so if the wheels are 5 x 114.3 they will not work. Also with a width of 9.5 you are going to need an offset of around ET30. So in short those wheels will not work.
Andy
Andy
Andrew/AWE
B8 Models
05-30-2013 10:22 AM
markozagreb
05-13-2008 07:29 PM
jaybquick
03-30-2006 10:12 PM
