A/C prob
Old Jan 31, 2008 | 12:04 AM
jzstuggie's Avatar
Default RE: A/C prob
Maybe a sensor could have been damaged? I have noticed that my temperature raises to operating temp really quickly after a cold start (about 3 minutes), since I had the maintenence done that is.
Old Jan 31, 2008 | 12:07 AM
jzstuggie's Avatar
Maybe I should mention I made a mistake of unscrewing a large bolt that connected pipeing to the condensor and cold mist started spewing out, but I tightened it back up immediatly.
Old Jan 31, 2008 | 12:12 AM
auditech79's Avatar
ORIGINAL: jzstuggie
UMMMMM.......yeah you should have mentioned that before. You let air into the system, so thats why your a/c compressor is turning on and off all the time but its not getting cold.
You need to take it to a A/C shop, evacuate the refrigerant, put it under a vaccum for 45 minutes and re-charge the system. Just like brakes, the system won't work with air in it.
Old Jan 31, 2008 | 12:16 AM
jzstuggie's Avatar
[:@] god d@mnit!!!
Old Jan 31, 2008 | 12:18 AM
jzstuggie's Avatar
Any guestimation on the what this will cost me?
Old Jan 31, 2008 | 12:24 AM
auditech79's Avatar
2 hours of labor and the cost of refrigerant. I would say about $250
Old Jan 31, 2008 | 12:28 AM
jzstuggie's Avatar
ow
Old Feb 1, 2008 | 09:36 AM
  #18
jzstuggie's Avatar
just took my car car to my local Benz tech and was told it is nearly impossible for a car to have air in the system. He told me if that were the case every car that had a refridgerant leak would have this problem.
Old Feb 1, 2008 | 01:16 PM
  #19
NH_USA's Avatar
OK So why didn't you get the Benz guy to diagnose the problem?
If he is so sure about the air he should have offered to re-charge the system cause you definately lost some refrigerant when you got the mist!
Old Feb 1, 2008 | 08:56 PM
  #20
auditech79's Avatar
Its not impossible to get air in the system but its hard to do, it doesn't matter,im just saying you need to re-charge the system to fix it anyways.
Its pretty easy to tell whats wrong with the system just by hooking up a set of manifold gauges to it.
