C5 A6 B2 S1 Malfunction in circuit every couple days
Old Apr 10, 2010 | 03:05 AM
jhuffman's Avatar
+1 ^^^^^
Old Apr 12, 2010 | 04:56 PM
Tuccatucca's Avatar
Just an update to this thread - I'm not sure what to think now.
Drove this weekend roughly, 800 km from Vancouver to Olmypia, Seattle, etc, and not one code since I cleaned the connector and mounted properly on the firewall...
Car ran awesome, and fuel mileage was best it's ever been.
As a side note to that, I had a brittle old check valve that had cracked and was causing a boost leak, which I fixed right before the trip. I never got any code for a boost leak, and didn't know it was there, and not sure how it could be related to any O2 code or if its completely unrealted.
But end result is I haven't had a code in almost 1000km so I think in this case it might have been the connection bouncing around that caused this, or the faint possibility of a boost leak causing a rich condition throwing the O2 out of spec. ???
Thanks to all who posted... For now I'm happy things are working!
Old Apr 12, 2010 | 05:04 PM
Midniteoyl's Avatar
If you had a air leak, that would through the O2's off cause the CPU is looking for a certain amount of air, according to the MAF, and the O2 is seeing something different.
Old Apr 13, 2010 | 10:16 AM
Tuccatucca's Avatar
Yeah I guess that's totally possible, I'm not sure if it was a coincidence or not. Some host on the intake manifold leaking at like 3PSI. Now that I fixed that, I'm boosting ~8.7PSI which should be about right for stock.
Old Apr 13, 2010 | 03:25 PM
Midniteoyl's Avatar
3psi is alot...
draculas
Nov 10, 2020 09:29 PM
Lisa B - Audi novice
Aug 29, 2011 10:58 AM
ppgoal
Apr 15, 2010 06:16 PM
ppgoal
Mar 25, 2010 07:38 PM
