A6Kraut |
11-04-2011 07:49 PM |
C5 intermittent no crank, no start
This morning on the way to work i stopped for fuel, when i tried to restart it I had to cycle the ignition to start position several times, it started. On lunch the car wouldnt start period, I had a battery light, so I checked my voltage, I had adequate voltage to crank (12.36V) and shortly after that check I cycled the key again and it started, as soon as it started running, I checked my charge back voltage and my alternator was putting 14.36 back into the battery, my mechanic tells me its an alternator problem, but I have worked on cars my whole life and usually generators dont give or warning or magically fix themselves, Im thinking ignition switch going bad, but I did just have the timing belt service and I wondering if its a simple issue of a loose connection at my starter or something, anyone had this problem///////please advise
