C5 intermittent no crank, no start
Old Nov 4, 2011 | 07:49 PM
A6Kraut's Avatar
Question C5 intermittent no crank, no start
This morning on the way to work i stopped for fuel, when i tried to restart it I had to cycle the ignition to start position several times, it started. On lunch the car wouldnt start period, I had a battery light, so I checked my voltage, I had adequate voltage to crank (12.36V) and shortly after that check I cycled the key again and it started, as soon as it started running, I checked my charge back voltage and my alternator was putting 14.36 back into the battery, my mechanic tells me its an alternator problem, but I have worked on cars my whole life and usually generators dont give or warning or magically fix themselves, Im thinking ignition switch going bad, but I did just have the timing belt service and I wondering if its a simple issue of a loose connection at my starter or something, anyone had this problem///////please advise
Old Nov 6, 2011 | 01:30 PM
hxgaser's Avatar
Is it cranking or not cranking at all? If it is not cranking at all, then it most likely is the ignition switch. Another thing to check is the ground cable.
m41n5t4y
Apr 9, 2012 03:58 AM
A6Kraut
Nov 5, 2011 11:09 AM
copper07
Nov 3, 2010 08:45 AM
99A4NOW
Apr 6, 2010 03:47 PM
42sport
Jul 17, 2009 09:31 AM
