calling all A6 gurus ,check this out!!!!!
Old Aug 12, 2008 | 02:13 PM
redmatador's Avatar
Originally Posted by lastls1
Could be a sticky carboned up valve that is not closing all the way. Hydraulic lifter can only compensate so much. Compression test done?? Just my a wild a** guess. My 2.8L '98 30V did the same thing occasionally.
the engine is not missfiring at all .so theres no problem with compression.The engine souds like a diesel motor.It makes a very low rattle at idle and tapping sound at around 1200 rpm.
Old Aug 13, 2008 | 04:16 PM
oc_audica's Avatar
i got the same thing it seems... only get it once the oil warms up
wish i knew what it really was, as it seems the answers are mixed
Old Aug 13, 2008 | 04:31 PM
auditech79's Avatar
The 2.8L oil pick up tube won't get clogged, so no need to worry about that. If you have already replaced the tensioner and given it the seafoam treatment, it might be a sticking lifter bucket. Does it only come from one side of the engine or does it sound like both? When was the last time you had the timing belt/water pump changed?
Old Aug 16, 2008 | 02:43 AM
redmatador's Avatar
THE noise is coming from passenger side valve cover .It makes arattling sound at idle and whenyou rev motor between 1200 and 1500 rpm it makes tapping sound like a bad lifter.i have replaced all intake lifter tappets (3x3) i also replaced chain tensioner, and it still makes noise.....it goes away when you rev motor past 1500 ..I even removed oil pan and inspected pump pick uf tube & screen...replced oil and filter . still makes noise.....
daze614
Jan 29, 2013 07:43 PM
pecka13
Feb 8, 2010 06:01 PM
vegastt
Mar 5, 2008 10:45 PM
Dj Spiel
Sep 26, 2007 10:31 PM
G
Oct 1, 2006 09:10 PM
