Camshaft Position Sensor (G40) Open or Short to Plus
hello!
i have a 98 mod. a6 with 2.8 engine and i had the timebelt changed and i get a wagcode 17746 - Camshaft Position Sensor (G40) Open or Short to Plus P1338 - 35- the strange thing is that i have used the camshaft alignment tool and the bolt for the crankshaft.. i pop loose the weels and tighten the belt too.. all the parts are brand new too! what the f... is the problem? i har redone it several times but no luck.. tnx for helping! |
Well try swapping cam sensors to the other side of the engine and see if the code moves. If it doesn't it still has a problem with the timing, take it to a mechanic.
why did i not think of that! gee... the simplest thing is sometimes hardest to find! c",)
i changed sides on the sensores and the code changed to bank 2.. tnx for the tip dude! (why the f... did i not think of it..)
default sensor.. went to the dealer to day and bought a new one,so i will try to change it to morrow. |
