Camshaft Seal Removal.
Old Apr 20, 2008 | 03:19 PM
xb70valkarye's Avatar
Default Camshaft Seal Removal.
I am in the process of changing out my timing belt and am doing the water pump, thermostat etc too. I also got camshaft seals as part of the kit and even though I do not have much of a leak from the seals I want to change them since I am in there. What is the best way of removing the old seals. My rental kit did include the tool for installation but not removal. Any ideas? Thanks.
Fred
Old Apr 20, 2008 | 03:32 PM
nemohm's Avatar
Default RE: Camshaft Seal Removal.
Fred,
there are detailed articles on audiworld about the procedure of repacement - cam adjuster gaskets and other...
Cam adjuster gaskets leaks are typical and object of replacement.
Cam seals are tricki to replace - required complete cleaness, dry seats and seals and NO engine startup at least for 4 hours.
Do you have the bar to hold the camshafts?
Old Apr 20, 2008 | 04:17 PM
Yes I do have the bar to hold the camshafts. But I had to remove the pulleys to get to the camshaft seals. However I have marked and kept everything in position. I will look into Audiworld. Thanks.
Fred
Old Apr 20, 2008 | 06:27 PM
modset's Avatar
he meant cam seals, not cam cam adjuster gaskets. i have searched high and low for cam seal writeup but can't find one anywhere
Rjk615
Aug 21, 2015 09:06 PM
BesI
Aug 20, 2011 01:13 AM
Dallas09
May 18, 2010 02:40 AM
Coupeboy
Nov 24, 2007 03:06 PM
