Can we install brake pads that come with no sensor?
Pads without sensors are the cheep way to go. And I mean CHEEEEP!
You can do it - just take the plugs and wires from the old pads, cut the wires, and solder the ends of the wires together near the plug. Smother the mess in RTV to protect the connection and push the plugs into the connector on the vehicle. Make sure you place the wires in a position so they don't get caught in anything.
You'll have to remember that you will not have a warning when the pads wear down.
Wires together (conducting) = Good pad
Wires apart (not conducting) = Worn pad
As an aside, my pads are not worn so my sensors are good. they just squeal and have no shims. Plus I've tried all types of grease to quiet them down and nothing.
Edit: Never mind. I understand what the first poster means. my question now is, is there a way to remove the sensor end that sits in the pad and place it in the new pads?
I understand that but if you solder the wires together so the ECU thinks they're good, when the pad does wear down and burns the end wouldn't that creat an open?
As far as I know, no.
If my current pads are fairly new i.e. have a good chunk of pad left, could i just replace the side that doesn't have the sensor with a new pad with shim? I think the majority of the noise comes from the pad without the sensor since it's on the outer part of the rotor.
Normally the innerpad wear out first - In any case if you change the outside pad the inner one will have less friction material and wear out long before the outer.
But why would anyone ever want to replace just one pad? Not a good idea - It will certainly mess up the braking because of the differences in friction between the two sides.
What are you greasing? Some types of pads just make a lot of noise. It is waht disk brakes do. It sounds as if you should just live with the squeeling or change the pads to something that is quiet..
