Cat converter
Old Apr 19, 2007 | 11:30 PM
xssnco's Avatar
Default Cat converter
2002 A6-2.7 turbo, 96k miles....Check engine light is on.Has been intermittent.No change in performance...Fault code is catalytic converter..Mechanic states that replacing both cat converters will cost approx $2600. How hard can it be? Are there after market products that work just as well as genuine Audi parts?? Should sensor be replaced at same time? I have seen some converters on Internet (Eastern) for about $340 each. Also saw Eastern converter for less than $70...
Old Apr 27, 2007 | 06:34 PM
sugarjay_98's Avatar
Default RE: Cat converter
I'd like to know the answer to this as well.
Old Apr 29, 2007 | 03:32 PM
jj2345's Avatar
me 3,my a6 has 89,000 miles,nowimnoticing,a rattle noice anytime i step on the gas,i can put them on,but audi is charging me 1,100 each
Old Apr 29, 2007 | 04:18 PM
auditech79's Avatar
The eberspacher cats that come from the factory are high flow cats and are just about the best cats you can buy unless you get a high performance replacment. If you bought a cheap set the performance would probably go down slightly. As for changing them you only have to do one but the other one is probably not far behind so changing both would be the best idea. As for replacing them yourself its a nightmare on a 2.7T. The easiest way to remove them is to lower down the rear subframe and let the trans hang down and you might have to remove some other crap, be glad its not a 3.0L because you almost have to removethe entire damn transmission to get those buggers out.
Old Apr 29, 2007 | 09:46 PM
prbayha's Avatar
Paying a grand or more for cats (each) is financial stupidity. Go to magnoflows site or talk to John at hottexhaust.com and you can get aftermarket high flow cats (very good quality and performance) with the O2 sensors etc.This has been the best course of action for others with this problems that I have talked to. Check it out before you waste $$ at the dealer.
Old Apr 30, 2007 | 10:23 AM
eclimax13's Avatar
or even better...get a nice set of downpipes or even turn ur factory ones into piggie pipes...which is basically gutting the precats which is what the sensors pick up anyway...and get a chip to turn off the rear o2 sensors....plus ull get a huge performance upgrade
Old Apr 30, 2007 | 02:44 PM
votblindub's Avatar
see, the thing with our pipes is that the cats are a part of a single pipe thats also a downpipe. this is why its stupid expensive. what you can do is get just the cats and have them cut out your old ones and weld the new ones in. most muffler shops can do it and it should be a hellova lot less than 2600 bucks
walters41907
Jan 31, 2010 05:00 PM
FixOrRepairDaily
Apr 4, 2008 10:20 AM
socaljoe
Dec 5, 2007 05:09 AM
swift_A4
Jan 22, 2007 09:58 PM
707782y
Feb 25, 2006 09:21 PM
