Catalytic converter replacement
Old May 23, 2009 | 12:28 PM
ebruce's Avatar
Default Catalytic converter replacement
One of my cats needs to be replaced but they’re like $700 - $800 each. I see a lot of “universal” ones listed on the web. Does anyone have any experience with these (like Magnaflow)? If universal isn’t the way to go, any suggestion where I could get one a bit less expensive, any brands that are recommended?
Thanks
Old May 23, 2009 | 01:26 PM
chefro's Avatar
I don;t know what year model you have, but for a 1995 FWD Arizona Autohausz sells them for $ 395.
$ 700-800 sounds like a double price. What place you're looking at?
Old May 23, 2009 | 08:20 PM
vta62.7's Avatar
I'm looking at also getting some aftermarket cats, and think I may go with VAST Performance piggy cats. If their claims are accurate it looks to be the way to go. They are rebuilt, but if they have a warranty who cares, right. $695, but you get $300 back for sending in your spent cats, and they claim to be efficient enough to pass Audi's tight tolerances (Efficiency code 0431, etc...).
Old May 24, 2009 | 03:26 AM
Midniteoyl's Avatar
The 'universal' cats are fine... thay are the same damn thing but need to be adapted... thats all. This charging $300-700 for a peace of ceramic and stamped steel is bullshit.
By a universal and save the cash.
Old May 24, 2009 | 03:29 AM
Midniteoyl's Avatar
Thats bs too... how do you 'rebuild' ceramic and platinum?
Old May 24, 2009 | 12:57 PM
ebruce's Avatar
Has anyone actually replaced their cat with one of these? I don't really want to buy and install one and then have it not work right. I don't know a lot about cats, but is one more efficient than another or any sort of variance which might cause a problem?
Old May 24, 2009 | 08:08 PM
Midniteoyl's Avatar
These are whats inside the cats:
This is whats inside of every cat. Some cheaper ones have one, better ones have two. It doesnt matter if its OEM or aftermarket, they are the same inside:
The difference in OEM vs Aftermarket is the pipes going in and out. Most 'universal' ones have just a straight pipe you have to adapt. OEM fit right up. Magnaflow has 'direct fit' cats with the correct in/out pipes.
Old Sep 6, 2012 | 01:46 PM
96 A6 QUATTRO's Avatar
Default 96 audi a6
bought two oem cats for my 96 a6 quattro, one Bosal and one Mac......they don't look like they are compatible.....any thoughts on installing cats from two different manufacturers?
Old Oct 7, 2012 | 12:10 PM
pokanyc's Avatar
Looking to replace my cats as well. Dealer wants waay too much for replacement. Even with the discounts my buddy in the parts dept can offer...the cats each costs $300-$350. I am soo ready for an aftermarket brand. Did the research and I am leaning more towards Magnaflow. I am gonna retire Audrey in a year anyways and keep her around for those snow storms that NY is infamous for (AWD is awesome in snow!) and get either an A3 or another A6. So having pristine cats is not pressing right now.
Old Oct 9, 2012 | 08:08 AM
Found converters on Ebay +/- $200 oem.......turns out didn't need them.......cleaned EGR out.....all good.
On a different note, every time I press the rear defront button, the fuse goes......any thoughts on this one?
