CEL on...
Old Jul 22, 2008 | 11:30 AM
hxgaser's Avatar
Default CEL on...
Well, the other day, I replaced my cam seals, cam adjuster seals and valve cover gaskets. Now I am getting a series of CELs and I want to hear what you all think.
First it was P1177. O2 sensor behind cat, bank 2 limit reached. What the hell, I erased it.
A couple of days later I get P1411 and P1423. Secondary air pump on both banks too low.
I am thinking it may be vacuum related. Also should I be looing at a specific vacuum line location? What do you think?
Old Jul 22, 2008 | 06:41 PM
hxgaser's Avatar
Default RE: CEL on...
I love duct tape.
Ihad a vacuum leak on the bank 2 combination valve hose. I just traced the vacuum line and noticed that the line was crimped around the inlet. Sure enough, there was a tear on the hose.
For now I duct taped the tear, but will replace the hose once I have a chance to go to a parts store. Just wanted to share the experience.
Old Jul 22, 2008 | 07:46 PM
kimi's Avatar
a fluctuation of your rev counter at idling speed couldrule out or in a vacuum leak dont you think? why dont you check the connection,black hose from the air pump to valve charmber bank 1 and that to valve cover right side tracing back to left side. this plastics break easily with age. plz keep me informed so i can do what ever i can to find a solution to this.youve been of tremendous contribution to this forum
Old Jul 22, 2008 | 10:21 PM
hxgaser's Avatar
Thanks Kimi. For now I taped up the leak and it seems to be running without a code. Readiness code hasn't set yet. So once I have the readiness code set, I will wait to see if there are any codes popping up again. BTW, did you ever get your timing chain issue resolved?
