CEL Codes: P0118, P0172, P0175
Old Dec 21, 2006 | 03:06 PM
audi2002's Avatar
Default CEL Codes: P0118, P0172, P0175
Does the P0118 indicate the coolant sensor needing replacement? Do both the P0172 and P0175 indicate both O2 sensors need to be replaced?
Codes:
16502
P0118
Engine Coolant Temp.Circ High Input
16556
P0172
Fuel Trim,Bank1 System too Rich
16559
P0175
Fuel Trim,Bank2 System too Rich
Thanks for the help.
Old Dec 23, 2006 | 12:35 AM
dankhound's Avatar
Default RE: CEL Codes: P0118, P0172, P0175
The first code is pretty much a surefire coolant temp sensor.
Most likly the other two arent o2 sensors. I would start by checking things that would effect both banks. Maf, dirty air filter,
Old Dec 29, 2006 | 10:39 PM
steviejayvaughan's Avatar
stopped up suction jet pump for rich codes
Old Dec 30, 2006 | 01:18 AM
Baskin 4.2l's Avatar
I would check your coolant reservoir and see if the connector is ok and there is enough coolant. As for the rich codes that motor do you have?
Old Jan 5, 2007 | 01:41 PM
audi2002's Avatar
I have the 2.7T engine.
Old Jan 5, 2007 | 03:17 PM
techbod's Avatar
EVAP canister purge valve or pipes to it blocked
eze_nc
May 19, 2015 04:02 PM
cnelson
Dec 30, 2012 09:29 AM
mberthia
Aug 3, 2012 08:45 AM
lleake
Sep 3, 2007 09:17 PM
ryanbelcher
Aug 3, 2005 09:46 PM
