Changed out Aux water pump now P0300 code!!!
Old Jan 5, 2008 | 06:14 PM
1fastt2's Avatar
Default Changed out Aux water pump now P0300 code!!!
Hey Guys,
The car ran perfect before I decided to change out the Aux water pump on my 01 2.7t A6. I beleive I have checked over everything and cant find anything I forgot to put back. The car now runs terrible and is throwing a P0300 code. Any help would be great!!!
Old Jan 5, 2008 | 06:21 PM
auditech79's Avatar
Default RE: Changed out Aux water pump now P0300 code!!!
Its a random multiple miss-fire fault code. It probably has nothing to do with the aux pump you just changed. Un-less you didn't torque down the intake manifold correctly you probably have a bad power output stage (ignition control module) or bad spark plugs. I would also double check to see if you pinched any wires going to the ignition coils, or if you didn't plug them all the way in.
Old Jan 5, 2008 | 06:32 PM
1fastt2's Avatar
Thats the thing, I didnt touch any of the ignition components and thought it would be awfully weird for an ignition component to just happen to go out right at that moment.
Old Jan 5, 2008 | 06:40 PM
auditech79's Avatar
S*** happens. I would double check you didn't pinch the intake manifold gasket or forgot to plug a major hose in. If it all checks out, eventually you'll get a dead miss fire fault code on one cylinder and it should help you diagnose it for the bad ignition part. Most likely a bad ICM.
Old Jan 5, 2008 | 07:57 PM
1fastt2's Avatar
Yea no doubt S*** happens, it just absolutely amazes me that I can pull it in the garage running 100% except for a little collant leak and button everything up go t pull it out and now it runs terrible... I had to of missed something however you may be right. Is there any way of testing those ICM's?
Old Jan 5, 2008 | 09:09 PM
auditech79's Avatar
You can't really test the ICM with available tools. You would need a pin out box with an LED lead that you would install on the wiring harness from the ECM.
However keep an eye on the fault codes, if it throws a dead miss-fire on like cylinder two perhaps, then you can swap the two ICM's from bank to bank and see if the miss-fire moved to a different cylinder. Both ICM's are sitting on the air box on a 2.7T. They should have a connector on both sides.
Old Jan 5, 2008 | 09:37 PM
1fastt2's Avatar
Could this thing have anything to do with the problem? I did some more looking around and noticed this was cracked, when I removed it the nipple fully broke off.....
[IMG]local://upfiles/47422/BD36AA4A000D4262874A0BD74711DFEB.jpg[/IMG]
Old Jan 6, 2008 | 07:45 AM
Vinny's Avatar
Yes it will have something to do with your problem because it is now dragging air into the system. bypass this if you can or replace/repair the item.
Old Jan 6, 2008 | 04:51 PM
auditech79's Avatar
Yep, thats the culprit
Old Jan 6, 2008 | 09:21 PM
1fastt2's Avatar
Im still kinda conserned...... I didnt think that small of a vacuum leak would cause that much havoc. Does anyone know the function of that little vacuum fitting?
