checking of a combi valve is good or bad
Old Feb 26, 2012 | 10:33 PM
copper07's Avatar
Default checking of a combi valve is good or bad
Does anyone know of a way to test the 2 combi value if they are good before just replacing them? I have changed the vacuum lines on my car, no leaks. I replaced the sap, code did not clear. The last piece is the combi valves, I need to know how to check them is they are functioning correctly.
Old Mar 4, 2012 | 11:36 PM
Nebuchadnezzar's Avatar
I know this thread has been dormant for about a week, but I just talked to an experienced Audi mechanic about this about a month or two ago.
If I recall correctly, you need to remove the vacuum tube and hook up a vacuum pump to it and attempt to pressurize it to 11psi (I believe, I could be wrong). Once it reaches that pressure the combi valve should open and the vacuum pump will no longer work indicating that the combi valve opened.
I hope that helps and hopefully I remembered correctly.
Old Mar 5, 2012 | 12:14 PM
copper07's Avatar
Hey thanks! I will give that a try. This darn p0411 code is driving me crazy and I need any help locating the part that is causing the issue.
Old Mar 5, 2012 | 03:23 PM
Worst case you'll have to get a new combi valve and replace it. New they are about $150, but I was looking on eBay last night and you can get a used one for about $30.
What side is producing that error? Driver's or passenger's side?
Old Mar 5, 2012 | 03:54 PM
copper07's Avatar
When I have the code read I just get "p0411 secondary air incorrect flow". Is there a way to tell which side is generating the code?
Old Mar 7, 2012 | 02:08 PM
kentetsu's Avatar
Hm, that may actually be the secondary Air injection system...
Old Mar 7, 2012 | 06:23 PM
copper07's Avatar
Do I need to be checking a different components then?
Old Mar 13, 2012 | 03:21 PM
kentetsu's Avatar
Run a search on Secondary Air Injection (or SAI) and see what you think...
Old Mar 14, 2012 | 12:35 AM
badinstincts's Avatar
whats a secondary air injection. why doesn't my car have one? do I get extra hp if I put it back in? lol
studiovette
May 15, 2013 04:49 AM
hartsoe1
Apr 17, 2013 02:00 AM
kevinruswick
May 19, 2011 09:36 AM
catmandu
Feb 17, 2011 07:22 AM
MadMaxGT
May 31, 2009 03:10 PM
