Coolant leak - quick fix?
Old Jan 19, 2008 | 02:29 PM
uli_muench's Avatar
Default Coolant leak - quick fix?
Hi folks,
My 2000 A6 2.8 quattro is having trouble again - we are losing small amounts of coolant.
The Audi shop (which I don't trust that much) said it's the auxiliary water pump and they would charge $995 plus tax to fix it.
Now I'm checking it myself, just can't find where this pump is located. I have read that the auxiliary water pumpis a common issue with Audis.
Does anyone know where I can find the auxiliary water pump and what I have to disassemble to get there?
According to the shop the second part responsible for the coolant loss is the rear main seal($1604 plus tax). Supposedly the entire transmission has to be disassembled which takes about 15 hours.
I find that hard to believe, especially since I have read some threads where folks claim to have the job done themselves in 2 hrs with $40 in parts...
Any comments are highly appreciated. I'm a little hesitant to give them3 grand just yet...
Also, has anyone had any luck with K-Seal, Seal-It and things like that??? It may do the trick since the leak is minimal. But I also heard some bad stories about clogging and subsequent water pump issues.
Thanks a lot for your help!
Old Oct 20, 2009 | 03:08 PM
steveorloff's Avatar
bump...
Old Oct 20, 2009 | 09:29 PM
kbunting's Avatar
We had a similar problem and it was the water pump.
Dealer charged $2,400.00 to replace it as the entire front of the car had to be moved out of the way to ge to it. Poor design. 2000 A-6 2.7 BiTurbo
If I had to do it again, and in your situation, I would use one of the sealant products since if it works, no more problem; if it does not work then you can still spend the $2,400.00 or more to have the pump replaced. The sealant is less than $5.00 so it is a cheap experiment
In older cars I have many times used , SUCCESSFULLY, PorterSeal or Barr's Leaks althought I am partial to the PorterSeal and used it many times with no damage to radiator or water pump or overheating. Just my opinion,
Kurt
Old Oct 20, 2009 | 10:04 PM
Jeffla's Avatar
Originally Posted by uli_muench
Hi folks,
The 2.8 does not have the Aux water pump! are you sure that's what they said?
Rear main seals generally are a pain in the a$$ to replace. Knock on wood that my A6 has not needed one buy my Volvo did and I think it set me back around 700.00, but the AWD transmission in an A6 would require quite a bit more work to remove fwiw.
Unless Audi does things differently, I don't see how a RMS (rear main seal) has anything to do with coolant. Oil yes, Coolant NO.
Old Oct 21, 2009 | 12:47 PM
NH_USA's Avatar
Woooooooow! Jelfa is right! Rear main has nothing to do with coolant and the 2.8 does not have an aux water pump.
Run away from that guy and find a real mechanic.
The first thing I'd look at is the expansion tank for a leak and then the hoses followed by the water pump. If it needs a new water pump do the timing belt, tensioners, seals, T-stat etc while you have it apart.
as for goopy seal stuff. They might work for a short time but sooner or later your going to hav eto spend the money to do it right.
Old Oct 22, 2009 | 03:30 AM
Midniteoyl's Avatar
Jan 2008....
No idea why it got bumped...
Old Oct 22, 2009 | 12:31 PM
NH_USA's Avatar
The bumper probably had the same problem ans was afraid to ask!
Cioffie
May 19, 2013 10:24 PM
Racerx220
Jan 18, 2011 11:23 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
juice88
Jul 13, 2006 02:23 PM
