Crankshaft sensor!
Hi, my car was shutting off at random, at the most uncomfortable times ofcourse... No hesitation, nothing just shuts off while driving or standing at a stop light, and would not start after that.
Got engine faults, is says P0332 - engine speed sensor - no signal. checked the manual, engine speed sensor aka frankshaft position sensor with grey plug and 3 contacts under the coolant expantion tank. Got it tested with multimeter, contacts 1 and 2 have 900ohms (if I'm reading myltimeter the proper way ;)) everything esle is no contact. Ordered new sensor, got it today, it shows exactly the same 900ohms, what;s wrong? The test does not mean anything and old sensor might be still bad, or something else going on>? Can I have a broken wire from sensor to ECU? Does anyone know to what pins in the ecu the sensor is connected so I can check the line? car is 2.8 aha, automatic transmission. Thank you. |
RE: Crankshaft sensor!
From the Bentley for AHA engine:
P0332 16716 Knock Sensor2 Circ. Low Input Sounds like you may be chasing the wrong sensor. Can you get a Vag Com scan? |
Sorry, my bet, it's P0322 =)
The scaner called it to be Engine speed sensor. I checked my dumb audi manual and the thing I bought is called the 'engine speed sensor' in there. Can you please check your manual for the correct code? Thanks. |
For P0322, the Bentley says:
[align=center]P0321[/align] [align=center]16705[/align] Ign./Distributor Eng. Speed Inp. Circ. Range/Performance [align=center]2 Dcy[/align] - Check engine speed (RPM) sensor -G28- http://127.0.0.1:8080/audi/icons/arrowdblright.gif Page 24-86 [align=center]P0322[/align] [align=center]16706[/align] Ign./Distributor Eng. Speed Inp. Circ. No Signal [align=center]Immed.[/align][align=center][/align][align=center][/align][align=left]Here's the process for checking the wiring between the ecm and the sensor:[/align][align=left][/align][align=left] - Check wiring for open circuit between ECM/test box and 3-pin harness connector. http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 1 to ECM/test box socket 67 http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 2 to ECM/test box socket 63 http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 3 to ECM/test box socket 56 http://127.0.0.1:8080/audi/icons/diamond.gif Specified value: max. 1.5 http://127.0.0.1:8080/audi/icons/omega.gif - Check wiring for short circuit between ECM/test box and 3-pin harness connector, according to wiring diagram. http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 2 to ECM/test box socket 67 http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 1 to ECM/test box socket 63 http://127.0.0.1:8080/audi/icons/diamond.gif Connector terminal 1 to ECM/test box socket 56 http://127.0.0.1:8080/audi/icons/diamond.gif Specified value: http://127.0.0.1:8080/audi/icons/infinity.gifhttp://127.0.0.1:8080/audi/icons/omega.gif If wiring is OK: - Replace engine speed (RPM) sensor -G28-. - Check readiness code http://127.0.0.1:8080/audi/icons/arrowdblright.gif Page 01-80 . If Diagnostic Trouble Code (DTC) memory has been erased, or ECM was disconnected, generate new readiness code http://127.0.0.1:8080/audi/icons/arrowdblright.gif Page 01-83 . [/align] |
Hopefully I understood the test completely:
term 1 to socket 67: term 2 to socket 63: term 3 to socket 56: 100% connection, 0 resistance. term 2 to socket 67: term 1 to socket 63: term 1 to socket 56: No connection Is that what it suposed to be? Then I have bad sensor right? I guess sensors own resistance does not really mean anything in this case. |
That's the way I read it. Didn't see any reference to a check of the sensor itself.
Good luck!! |
Well, I'll replace it and go for a ride, it should be abvious wery soon if it helped or not [8D]
Thanks. |
hey, so did you have any avail with the crankshaft position sensor? i have the EXACT same problem and have been trying to fix it for weeks but can't seem to get it. hopefully there will be some response as i am STUMPED! I had the local indi shop replace the crankshaft sensor and it didnt do anything....
