CV Boot kit - Which brand to get?
My outer CV boots are cracked and need to be replaced. The cheapest part I found is here for ~$15:
http://www.autohausaz.com/search/pro...V%20Boot%20Kit
Another more expensive part is here:
http://www.car-stuff.com/exclusives/...6-cv_boot.html
for $25
And it looks like I need 2 of them.
Is there any difference in the quality of the parts? Is there a better brand I am not aware of that everyone swears by?
for $25
If you have a build up of grease on the inner wheels I would swap out the axles, cheaper in the long run.
I had torn boots and grease caked on the inner wheels my mechanic recommended I changed out the axles, explaining damage could have been caused to the joints/knuckles.
All plausible if you think about it. Road dirt and grim mix into the lubricant deleting lubrication and increasing friction.
I think you just got tricked LOL. I am sorry but don't listen to that... basiclly what you are saying is that whenever you have a torn CV-boot you should replace the axel.... Your mechanic is a moron I am sorry. A audi master tech would geek out at you... unless you were driving around for a couple months with it torn. You will know when you need a new axle trust me. Repair the CV boot and you will be good to go. Replace as quick as possible... Check every month or so on the CV-boots for dmg and you will be fine
This forum is here to help people not to bash other members because you have trouble comprehending there terminology.
So 60 mph at 5000 rpms is normal. Yeah! I would take advice from this guy
