Dashboard not working, how do I fix this?
Old Jun 8, 2007 | 02:27 AM
cooleststan's Avatar
Default Dashboard not working, how do I fix this?
I was wondering if there is a cheap way to fix this. The LCD screen in the center console no longer works. When I turn the car on, it still says "OK" in yellow letters, but the part beneath that (the red part) no longer works. The top part and the bottom part both work, so I can see which gear my car is in as well. Its just the middle lcd part (that displays mpg and temperature) does not work. Any way to fix this without going into the dealer?
Thanks
Stan
Old Jun 8, 2007 | 03:08 AM
R Evolution1's Avatar
Default RE: Dashboard not working, how do I fix this?
I doubt there is a easy fix for the LCD display without getting it completely replaced, they seem to go bad on most audi's, you might want to view this thread https://www.audiforums.com/m_389750/tm.htm
Old Jun 8, 2007 | 06:52 AM
sljone's Avatar
Member
Because of the way the cluster is set up there is no other way to fix this but to replace the cluster, and if you do replace the instrument cluster you will need to have it programmed. You can check out this website www.aaellc.com they transfer the info from the old cluster to the new one or you can have the dealer do all the work but that may be costly.
Old Jun 8, 2007 | 11:47 AM
mpw2.7T's Avatar
Is the display completely blank? If so, are you sure you haven't turned it off? I've seen several postings where that was the case.
Old Jun 8, 2007 | 01:05 PM
yes, the lcd is compeltely blank. I didn't know you could turn it off! How do I turn it back on?
Thanks
Old Jun 8, 2007 | 05:52 PM
reaper's Avatar
by pressing the reset button on the bottom of the wiper stalk.
Old Jun 8, 2007 | 10:06 PM
toolagit2qwit's Avatar
Try this link for replacing Instrument Cluster Replacement-It's a DIYer tutorial and pretty detailed-Good Luck
http://www.audiworld.com/tech/elec106.shtml
Old Jun 9, 2007 | 03:09 AM
wow, thanks guys, I think my mom jsut accdinetally turned it off. I hit the reset button and the lcd works perfectly now!
Thanks a lot!
Old Apr 13, 2008 | 10:48 AM
A6Rob's Avatar
Reaper/mpw2.7T: You Rock!
Same thing happened to me, thought I shorted something. Was ready to start replacing fuses but the reset took care of it.
Old Apr 13, 2008 | 11:06 AM
audia6s's Avatar
First rule...see if it's powered on or plugged in
