Did brake pads and now the brakes are weak
I did pads on my wife's 03 A6 and after doing the pads the brakes where quite spongy. I never opened the bleed valve or removed any parts. I just spread the calipers and R&R'd the pads... any idea what's up? Should I just go ahead and bleed the brakes?
Small fluid bottle thing is worthless. If you have the dough, then get a pressure bleeder like the motive powerbleed. If you are a cheap bastard like me, and still want something that actually works, then get a hand pump type bleeder like Mityvac. I noticed that Sears actually has a full metal body one that is cheaper than the plastic Mityvac.
Any wife that is allowed to drive an Audi had better be willing to sit in the vehicle and pump the brakes while your bleeding them.
Make sure the master cylinder is full of fluid and have her press on the brake peddle. Open the bleed valve (with a small hose attached whose end is in a jar) and tell her to let you know when the peddle hits the floor, tell her to keep it pressed down. close the valve and tell her to pump the brakes a few times --Repeat this multiple times at each wheel making sure you refill the master cylinder.
If your wife isn't willing to help tell her that she will soon be driving a Yugo...and the cute blond at the office will be driving her Audi.
PS If you follow these instructions and she slaps you up-the-side-of-the-head Don't blame me --Your the one that married her! not me!
