Directionals on 2000 A6 2.7
Old Nov 12, 2007 | 10:56 PM
cdpoppert's Avatar
Default Directionals on 2000 A6 2.7
My directionals started to work infrequently a few weeks ago and now they do not work at all. Is there a quick easy fix for this?
Old Nov 12, 2007 | 11:01 PM
auditech79's Avatar
Default RE: Directionals on 2000 A6 2.7
Are you referring to your turn signals? Then yes there is a common problem with them, see the red triangle above the radio? Thats the hazard/blinker relay, they commonly short out causing the turn signals to work intermittently.
Old Nov 12, 2007 | 11:19 PM
cdpoppert's Avatar
I believe this might be the issue. Is there an easy and inexpensive way to fix this relay and prevent it from shorting out again?
Old Nov 13, 2007 | 12:54 AM
daroshi's Avatar
Buy a new "Hazard Switch" for a mere $22 http://www.genuineaudiparts.com/. Carefully pry off the woodgrain panel surrounding the hazard flasher switch, push in the tabs on the old switch & pull it out, disconnect the plug on the back of the switch. Should take 10 minutes (45 minutes with a beer break!)
Old Nov 13, 2007 | 12:56 AM
auditech79's Avatar
You should pull out the radio as well if you don't wanna break the wood trim.
Old Nov 13, 2007 | 01:25 AM
Four Ring Circus's Avatar
SoCal Crew Member
ORIGINAL: auditech79
I had the same issue in my old Jetta and this was the solution. Cheap fix.
Old Nov 13, 2007 | 10:05 AM
cdpoppert's Avatar
The hazard lights seem to still work fine. Could this hazard switch still be shorting out the turn signals?
Old Nov 13, 2007 | 10:35 AM
daroshi's Avatar
ORIGINAL: cdpoppert
The switch contains 2 relays on a single cicuit board. One is for the hazard lights, the other the turn signals. One can (and usually does) fail independant of the other.
Old Nov 14, 2007 | 06:59 PM
tonyk's Avatar
I too had the same issue. I used a wide blade putty knife to pry out the panel and it worked well. I didn't see the need to pull the radio. This is absolutely a job that you can do and save a bunch vs. having the dealer do it.
Old Nov 14, 2007 | 07:24 PM
auditech79's Avatar
Since the radio takes a whopping 5 seconds to pull out i don't see why it would be a hinderance, but whatever floats your boat. Here is a pic of the radio tools which you ALL should have.
