DIY for ignition switch???
Anyone have one?
I need to change mine out. Getting the common ignition switch problems. Thanks. |
Thanks.
Will I need new keys? Also, on a 98 do I have the immobilizer system? |
Not need for new keys. Your tumbler will stay the same. You don't have an immobilizer. It was an option starting on 01 and on.
I believe the only difference on 98 to 01 is that you use a standard hex bolt, instead of a triplesquare bit for the main bolt holding the steering wheel. |
Cool thanks.
