Driver window problem
Well, maybe. But I'd consider the entire electronic system of the window; from the switch to the motor. It may bne just the motor, it may be just the switch, or it may be both (bad communication). It may be one of those trial by error things... unfortunately.
Places to buy...? Dunno... I'll look around.
Rings for life,
Your problem is most likely caused by a window frame that's worn out. Your window will bu pushed up and because there's room between the glass and the frame, the glass will be pushed up under an angle wich causes resistence. The resistence then exceeds a certain limit which will activate the automatic safety stop, to stop the window going up and then going down. replacing the frame will most likely solve your problem.
Good luck
Good luck
Welcome to the forum AudiFreak!
This is a great site. We keep the dialogue friendly and the attitude positive. The info is well received by all and we are here to help anyone with the need. I hope you find it to your liking as well.
If you're not familiar with this forum, please click the START HERE! link. There you will find a forum vocab list, an Audi forum terminology list and an Audi lexicon list. They should be very helpful to you if you're not familiar with the jargon.
Please feel free to ask any question, but double check the archives first. Many questions have been archived and, quite often, the answers are comprehensive.
Interesting idea AudiFreak. Does the safety stop, you refer to, cause the motor to reverse direction?
