DTC Code 17550
Old Apr 21, 2011 | 10:28 AM
sukisuru's Avatar
Default DTC Code 17550
17550 P1142
Load Calculation Cross Check Lower Limit Exceeded, what does it mean?
Thank you
Old Apr 21, 2011 | 08:29 PM
TwinTurboC5's Avatar
You need to check for any vaccum leaks. If none are found, then the problem is with your MAF. (ECM is assuming a certain amount of power will be produced for the amount of air coming through the MAF- if the actual amount is different than the calculated amount, the power output will also be off, and will set off the MIL This can be due to MORE air getting in than calculated due to a vacuum leak, or the MAF being faulty and calculating an incorrect amount.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
