emergency brake handle frozen
Old Jul 21, 2008 | 09:28 AM
reverend's Avatar
Default emergency brake handle frozen
since i have got my car i can't pull the e-brake. it is stuck in the off position. any ideas?
Old Jul 21, 2008 | 07:30 PM
auditech79's Avatar
Default RE: emergency brake handle frozen
The cable is probably rusted, get under the car and check the cables to the rear brake calipers, then check follow them back to the front of the car. If the cable looks like it has rust on it, try spraying WD-40 or PB blaster on the rusted areas and keep trying to release the handbrake.
Old Jul 22, 2008 | 11:51 AM
reverend's Avatar
i will give it a try
Old Jul 26, 2008 | 09:19 PM
a6hcw's Avatar
I have a 1996 A6 Quattro, which had both parking brake cables broken when I bought the car. Both of the cables broke at the large pastic blocks they pass through. To replace the parking brake cables, the rear exhaust and some of the heat shieldsmust be removed. I have a 1998 A6 Quattro wagon which had a frozen parking brake lever on the right rear caliper.
The BentleyPublishers.com Audi shop manual will help to do this work. The exhaust pipe hangers are an insane design, and hard to remove and install. The front parking brake cable spring clips are also a bad design. They are hard to reinstall with the drive shaft in the way. However, if you wire the spring clipsto a wooden dowel you can install them without disconnecting the drive shaft.
Mhuntington
Apr 24, 2013 10:48 PM
samualhall
Apr 15, 2013 04:31 PM
treyg
Feb 5, 2011 12:48 PM
sleeperwagon
Jul 16, 2009 01:32 AM
fidelite
Feb 3, 2009 11:04 PM
