error code A6
Old Jun 13, 2005 | 12:48 AM
Henrymcf's Avatar
Default error code A6
After a small rear end accident (i was hit) the check exhaust light came on. Shop says the error codes are po1198 and po1199 and that the po1199 means the ground fault has failed on the computer. Does this sound like something that would be caused by a small bump? TIA
Old Jun 29, 2005 | 02:01 AM
Bluenose's Avatar
Default RE: error code A6
Is the car running the same? I've had an exhaust sensor gone for quite a while on my 96 A6, my mechanic cautioned against replacing it as the other 4 sensors have a tendency to go if you do, and they will screw up the way the car runs and need replacing.
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
NewJ_A4
Feb 3, 2008 01:09 AM
winter001
Jan 8, 2008 07:50 PM
mikehh
Aug 25, 2006 03:35 AM
