ESP light
Old Dec 26, 2007 | 12:04 PM
gcan's Avatar
Default ESP light
I have a 04 2.7 and when it snows and gets slippery out and the tires break loose, the ESP light willflash on each time it slips,it also makes a noisesimular to the ABS brake noise.
Is this a normal function for the Quattros?
I just had the timing belt service done last week at 74000 and the car had no stored codes.
Old Dec 26, 2007 | 01:37 PM
auditech79's Avatar
Default RE: ESP light
The light flashes when the ESP is activating, you probably have bald tires, or you need to upgrade to winter tires that grip better.
Old Dec 26, 2007 | 01:57 PM
gcan's Avatar
I guess that the Pirelliall season40 are not the best snow traction tires,flashing lights and noises do however concern me.
If that is normal then I am okay with it... better tires would help...Thanks
Old Dec 26, 2007 | 02:02 PM
auditech79's Avatar
Yeah its normal, the abs activating sounds like a loud pulsating grinding sound when activated.
Old Dec 26, 2007 | 04:12 PM
Four Ring Circus's Avatar
SoCal Crew Member
Thought so... theABS gets activated to cure the slipping, right?
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
