ETKA Epics5
I realize this is the wrong forum for this question but I can't find any other place that it fits so I'll ask here.
I have ETKA Epics 5 - the program that shows all the parts with part numbers for Audi s- It worked great with XP-Pro but I can't see the whole screen with Vista home... I've tried almost everything without sucess. It loads OK but the right side and bottom are cut off so I can't access the buttons.
Does anyone know if there is something I can do short of going back to XP-?
Will the newer Epics 7.1 work with Vista?
Can I upgrade?
I searched the ETKA site and found very little info --
Can I upgrade?
I have a Cannon MultiPass F30 printer, copier, scanner, which won't work with Vista, because there are no Vista drivers available from Cannon.
So, you may have to get an old XP-Pro computer, if you can't find a solution.
I'm beginning to hate Vista --
Like a6hcw I find that there are numerous pieces of equipment and programs that don't work with it because of compatability problems or lack of drivers. To make matters worse HP does not recommend downgrading to XP because of "driver compatability problems" so it looks as if I'm screwed.
The guys in my IT department will not put VISTA on any computer we buy because of all the problems so the situation is wide widespread. I was forced to buy a new computer when my XP machine died - now it looks like I'll have to purchase another new computer that will run XP so I can run the programs I need.
