Fuel Sensor Calibration - 2006 A6 4.2L
Hi Guys!
Can't seem to figure it out. I had my mechanic change both the fuel sensors inside the tank (there was bad wiring, etc.). But the gauge on the dash still does not show the correct amount, the computer that shows the remaining mileage is also off.
I understand that it needs to be calibrated. Does anyone know the procedure or the code to put in to make it work?
thanks!
thanks!
If the sender where replaced then, just fill up the tank. Turn the key but don't start the car for 60 seconds. Then turn the ignition off, then start the car. Take it out for a 10 mile drive. It should calibrate it's self. That what I did when they replace mine.
Fill the the tank up, see what happens.
I checked with my mechanic, and they did replace everything including the sender. I tried to follow that procedure of turning ignition on and not starting the engine but it did not work.
Mechanic says that there is a calibration code that needs to be entered through the computer.
What seems to be happening now is that the gauge is off by around 4-5 gallons. So is the trip computer.
Here a link for TSB list: Audi A6 TSB List
drft1
Aug 29, 2010 01:36 PM
drft1
Jul 5, 2010 12:18 PM
