Fuses ???
Old Dec 27, 2008 | 03:29 PM
T. Cloyd's Avatar
Default Fuses ???
Good afternoon everyone... I have an A6 2.8 quattro that I am having some difficulties with. One morning before work, I hopped in and the wipers, low beams, turnsignals,and heat, ( which blew softly but did not blow out with the fan setting on high ) all stopped working @ the same time. I changed fuses to all but still nothing. Would anyone have an Idea about what's up ? It is a 2000 with 117k on it......
Old Dec 27, 2008 | 03:58 PM
T. Cloyd's Avatar
Going to go check relay.......
Old Dec 27, 2008 | 06:10 PM
NH_USA's Avatar
What does "Blew softly" mean?
Old Dec 27, 2008 | 10:22 PM
T. Cloyd's Avatar
What I meant was if you put your hand over the vent you could feel heat blowing very lightly... Even when thee fan was all the way up...
Old Dec 27, 2008 | 10:26 PM
T. Cloyd's Avatar
I did a little more searching, and it seems likely that it would be the relay... will attack it tomorrow, hopefully that is it...
Old Jan 6, 2009 | 09:16 PM
SportA4's Avatar
What did you find? What relay did you suspect? I have an A4 1.8T Quattro with the same symptoms. I suspect something in the Combi switch because I can get the functions to work by running a jumper wire across the harness end of the terminal. I've had the switch all apart and I cannot see any obvious problem.
andyandjohn
Jul 17, 2012 10:40 PM
Vilkku
Mar 8, 2007 06:53 PM
trejo21
Feb 17, 2007 10:41 PM
nyaudia498
Jul 2, 2006 01:58 PM
hellhouse
Mar 2, 2006 05:21 PM
