gas
Old Apr 25, 2008 | 06:00 AM
goodkarma1947's Avatar
Default gas
ok, yet another dumb question ...
what gas do you guys (especially stock) usually use on a 2001 2.7T?
i know it says unleaded ... and in the manual somewhere, it says premium recommended for best hp/performance
i tend to use premium when i'm going to be riding on the highway for long distances at high speed and regular when i know i'll be in town for a tank or 2
haven't noticed any problems ... but who knows?
so, any hints/ideas, etc??
thanks,
dennis
Old Apr 25, 2008 | 09:54 AM
2000_2.7t's Avatar
Default RE: gas
91 octane
Old Apr 25, 2008 | 11:53 AM
event's Avatar
Member
Default RE: gas
Due to high compression ratio you should use premium fuel, lower octane fuel will cause your engine to knock and in the long run this can cause damage, it isn't a question of how fast you drive but how long you want your engine to last.
Old Apr 25, 2008 | 12:23 PM
Coors's Avatar
Default RE: gas
I always run/ran premium. Hence, I'm moded, but even before the mods I ran 93+. Cars with turbo-chargers should run on premium for maximum performance. Your robbing your car of it's true potential. Carbon build up is more likely in the event of lower ocatne use. IHMO
Honestly, how much are you saving at the pump by using lower ocatne? You will eventually pay for it down the road in costly serivce and repairs.
Were at the mercy of the greedy-dirty burecratic fuel mongruls.
Old Apr 25, 2008 | 08:36 PM
Default RE: gas
i have other friends with turbos in their cars, and the dash & gas tank say "premium only" ... not just "unleaded" like ours
as for "91" ... up here in nj, my choices are "87" (regular), "89" (mid) and "93" (premium) ... if there was a "91", and i could save a few pennies, i would ... right now there is a 0.30 to 0.40 per gallon difference ... or $6 to $8 per full tank
i don't see any knocks or hesitation or any other problem with regular for around town ... but i have been using premium for high speed highway driving (don't want a problem trying to pass at 70 or 80 or more mph
but, if the consensus is that we should only use premium, then i guess i'll bite the bullet ... what's odd is that the owners manual doesn't "require" it
dennis
Old Apr 25, 2008 | 09:56 PM
joetm's Avatar
Default RE: gas
def only premium
Old Apr 25, 2008 | 10:12 PM
event's Avatar
Member
Default RE: gas
ORIGINAL: goodkarma1947
Yeah general low speed driving shouldn't really be a problem, but if you are driving at higher speeds (not sure of the range), you're engine will suffer mechanically, which I wouldn't chance.
I'm kinda **** too, so I wouldn't mix gases, I in fact only use premium Chevron/Techron, and I keep the tank more or less half full at all times.
Old Apr 26, 2008 | 10:38 AM
joetm's Avatar
Default RE: gas
yea lettin the tank run out is not good ... dirt and other crap will get sucked right up
Old Apr 26, 2008 | 08:34 PM
Default RE: gas
i try not to let it get below 1/2 tank ... plus, when refilling only a 1/2 tank, it doesn't seem as burdensome (LOL)
