Have a code can someone help
Old Aug 17, 2006 | 07:27 PM
sntemp's Avatar
Default Have a code can someone help
Check engine light came on in my 2002 A6 3.0 took it to Auto Zone and got the following code...
P0421
Anyone know where my problem is and how to fix?
Old Aug 18, 2006 | 12:26 AM
mpw2.7T's Avatar
Default RE: Have a code can someone help
From the Bentley:
2 hits for the 3.0-
P0421
16805
Primary catalytic converter, Bank 1 Too inefficient
- Replace catalytic converter
P0421
Warm Up Catalyst Efficiency Below Threshold Bank 1
- Check Oxygen Sensor (O2S) and oxygen sensor control before Three Way Catalytic Converter (TWC) Page 24-124
- Check Oxygen Sensor (O2S) and oxygen sensor control behind Three Way Catalytic Converter (TWC) Page 24-135
- Check catalytic conversion Page ST-43
Sounds like an O2 sensor or catalytic converter problem.
Do a search for the code on AudiWorld. I found this -
http://forums.audiworld.com/a6/msgs/623856.phtml
Old Aug 18, 2006 | 12:55 AM
sntemp's Avatar
Ok, I went back to Auto Zone and they gave me the printout for the code.
It says...
"The PCM has determined that the warm up Catalyst efficiency for bank 1 is below threshold for the current engine operating conditions. (bank 1 identifies the location of cylinder #1, while bank 2 Identifies the cylinders on the opposite bank)
So I'm figuring it's the O2 sensor and I will attempt to replace. has anyone here ever replaced them and does anyone know which side this is? before or after the converter? I read through some of the searches and there is a lot of debate on what side is what.
Any DYI info out there?
Old Aug 18, 2006 | 01:02 AM
sntemp's Avatar
I just thought of something, so maybe someone can help with information.
Is the O2 sensor and Converter part of the emissions warranty? And if so aren't the emissions warranties longer than the standard warrant?
The car is a 2002 model and has 55,000 miles on it
Is Audi responisble for fixing it?
Old Aug 18, 2006 | 09:53 AM
nolnbug's Avatar
Cat yes, O2 no The cat has a 8 year 80000 mile fed. warranty
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
