Hazard Relay
Old Oct 24, 2009 | 01:21 PM
catdog's Avatar
Default Hazard Relay
My relay has 9 pins # 4B0 941 509 C
The replacement has 10 pins # 4B0 941 509 K
My harness has a blank where the 10th pin would go so it seems it should work anyway.
When I put the new one (10 pin) in and start the car I hear a sound like small electrical arching.
The problem was intermittent blinker noise, no buzzing noise before replacement. I put the old one back and the arching noise goes away but the ongoing blinker noise is still there.
Any thougths?
Old Oct 26, 2009 | 08:41 AM
catdog's Avatar
anyone ?
Old Nov 8, 2009 | 01:13 AM
plainaudiguy's Avatar
IIRC from replacing my flasher a few months back, K is the current one and is ok to use. I think I had a 9 pin originally and now have a 10 pin unit. You probably can't even buy the 9 pin models anymore. Connect your new unit, but don't install it all the way in the dash and try it. Do you hear arching in the relay itself? You may have a bad relay.
jcollege
Jun 27, 2013 06:17 PM
0956JLee
May 20, 2013 08:19 AM
dsthomlinson
Sep 12, 2010 12:05 PM
randomloginname
Apr 1, 2008 11:13 PM
modset
Feb 26, 2008 06:51 PM
