headlight bulb a6 1999
2how do you install a new blub on the passenger's side headlight? Im mechanically challenged, I removed the 2 screws on top of the headlight and the metal clamps yet the headlight wont come out. any detailed help would be greatly appreciated.
RE: headlight bulb a6 1999
You don't need to pull the headlight out. Undo the metal clamps that hold on the black plastic cover. Pull the cover off, this will require some effort. Once you get the cover off, you'll see the wires leading to the bulb harness. Twist the harness in the socket and it will pop out. Pull the old bulb out and replace. Make sure not to touch the new bulb on the glass with bare skin or it will create a hot spot (if you do, just clean it with rubbing alcohol).
Good luck
Good luck
