headlight help
Behind the headlight is a black cover that is held on by two metal clips. Pop the clips out of the way, then pull the cover off. Twist the harness out of the socket.
Make sure you don't touch the new bulb with your fingers, as the oils will create a hot-spot and cause premature failure.
paulywalnuts446
Feb 3, 2013 02:41 PM
blks4
May 20, 2007 03:04 AM
Influentialstylez
Mar 29, 2007 04:30 AM
