Heat Intermittent on 99 A6 Climate Control
Old Nov 28, 2005 | 04:04 PM
kc's Avatar
kc
Default Heat Intermittent on 99 A6 Climate Control
My 1999.5 2.8 A6Q has developed an intermittent heat problem. Sometimes, the heat comes on fine. Other times, when the engine is definitely warmed up, cold air pours out regardless of temperature setting, recirc/not, or whatever. The car had the full coolant flush and fill about 10K miles ago, so I don't believe that there should be any crud in there. I replaced the temperature sender since the gauge sometimes read dead cold when I knew the engine was warm, and now the gauge reading is "normal." But my heat still has the problem: it is intermittent. This morning, while in for something unrelated, I had it checked for codes, and there were none (heating system or other). Any ideas what else I can check?
Flymaninc
Oct 20, 2009 08:22 PM
tmanley
Sep 12, 2009 09:50 PM
dannebrog
Oct 26, 2006 03:12 AM
