Help!!
I went to put in a new expansion tank, and when I pulled off the hose from the top of the tank, the little nub on the t that goes between that and the other two hoses just shattered. It was very corroded. Where can can I get that little t piece?!? Any help would be GREATLY appreciated!
I have the 2.8 in my A6 and I don't know if the tee is the same as yours, but mine was plastic and it broke a while back and provided me with an unscheduled opportunity to replace some coolant. I replaced it with a plastic vacuum tee just to get home, but then I ordered a stainless steel tee fitting from McMaster-Carr (I think it was less than ten bucks) and I haven't had any trouble since. I also replaced the spring clamps with regular hose clamps while I had them off.
I can get you the part number and the specs tomorrow. For some reason I can't get on to the server at the office right now to look it up, but if I remember right, all three hoses were the same size on mine. I'll get back to you.
I'm with huffman, OEM with Audi's seems to mean unreasonably priced.
