help 2.7t misfire
Old Dec 20, 2008 | 10:45 PM
djez016's Avatar
Default help 2.7t misfire
ok so as of yesterday I have had this bad *** misfire so thinking nothing of it figured just need plugs it has over 151xxx miles so picked up a set pre gaped put them in and still a misfire but by this time it was late so no trips to autozone for codes but i went 1st thing this mourning and got the cylinder2 misfire so ok i pick up a coil pack install on cylinder 2 (http://autorepair.about.com/library/...bl-fo-1251.htm) and still have a misfire went back for the codes again and got a random misfire code now wtf so any ideas what could be the problem im staying up night untill i find out whats going on here lol
01 2.7t
Old Dec 21, 2008 | 12:00 AM
Jeffla's Avatar
I believe you might need and ICM (ignition control module). I know NOTHING about the 2.7's (or the 4.2 for that matter) but I believe they have an ICM and it is in the air box.
Old Dec 21, 2008 | 03:10 PM
loach1's Avatar
2nd on the ICM.
There are two on the top of the airbox. Switch the brown connectors with the black connectors to see if the problem follows the ICM - reset and look for misfire on cyl 5. If it is on 5, you have a problem with your ICM. If you are handy with a soldering iron, pry the top off the ICM and locate the broken connection, clean out the goo and solder it back together.
Old Dec 21, 2008 | 07:48 PM
djez016's Avatar
it was the icm now about prying off he top i dont see that possible
Old Dec 22, 2008 | 07:58 AM
loach1's Avatar
The rectangle with the rounded corners and the writing comes off. Use a knife to get it started then a screwdriver to lift it up. Nothing to lose at this stage - could save $200 if it is a loose connection (usually is from what I can gather).
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
