Help, ABS and ESP light on!!
Old Jan 24, 2007 | 05:51 PM
rhs98jeep's Avatar
Default Help, ABS and ESP light on!!
Hey guys, I mostly lurk here and read up on the car. However have a problem and cant find any info on it. The ABS and ESP light come on and stay on at all times. Started the other day, checked the fuses, nothing wrong. Also noticed my Cruise Control didnt seem to be working either. Is there a relay I could check under the hood? Any insight on this?
The car is a 2003 Audi A6 3.0
Appreciate any help
Old Jan 25, 2007 | 01:33 AM
foorausfoora's Avatar
Default RE: Help, ABS and ESP light on!!
i have the same issues, and i am currently researching if i find any GOOD info i will def post.
Old Jan 25, 2007 | 03:43 AM
rhs98jeep's Avatar
Thanks foorausfoora, appreciate it. Hate to take it to the dealer.
Old Jan 25, 2007 | 04:17 AM
SouthboroAudiGuy's Avatar
Did either of you have to get your car jumped recently? I had a dying batter a while back (since replaced) and on one event when the car was REALLY slugish to start, I had those lights come on. Check engine codes later and they registered a "low voltage" event -- dying battery. Replaced the battery and cleared the codes. No problems ever since.
Good luckl
Old Mar 11, 2012 | 10:04 PM
Akan McPherson's Avatar
Default reply to post
I have the same issue the other day my car died. I had to get a jump then the next day the esp and abs lights came on. I will try the battery thing and let you know if that works
Old Mar 12, 2012 | 12:29 AM
budhani786's Avatar
Scan the car for codes. Scan the engine and abs. Could be a brake light switch.
Old Mar 12, 2012 | 03:44 AM
bigdadi's Avatar
check your brake lights. step on brake pedal and have some one check it for you. It can be the 'brake pedal light switch'.
The car pickup speed is sluggish, another symptom.
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
